Track rats rejoice!
All the positive press reviews I’ve seen of cars with the PP have also had the Cup2R tires. Those tires alone will dramatically positively transform the handling of any car… in optimum conditions.
And there lies the rub for me. There’s no way I can justify running 2R tires on the street, I’d seriously limit deciding to drive the car only in completely dry and warm conditions. This is supposed to be an awesome daily driver, not some Sunday Driver Supercar.
And if I’m not running 2Rs, I’m not paying a $9k up charge for the rest of the components which on their own cannot be worth the price (I’m sold on the CCBs for the dust elimination).
Dustin told me when he swaps the tires to get the order accepted, a credit is issued for the Cup2R. Not sure the exact amount. While the correct size for the Cup2R is listed on Michelin's website, it's the Porsche spec. I would assume the next manufacturing run would have the TPC version.
Interestingly, the Canadian build config shows the price for the Precision Package. It is CAD20,700.
I’m not seeing 2025 Blackwings on the Cadillac.ca site yet.
Maybe I’m linking with a cached version?
Please send the link you’re using as I’m curious to see how much more my car would have cost as a ‘25.
2025 models are not yet showing on the site. However, a direct link works. I posted it here:
So maybe you get a $7-800 credit opting for the 4S vs 2R, that leaves about $8k that you’re paying for some software and control arm tweaks that won’t perform nearly as well as when running anything other than 2R tires.
The 2R tires are the key ingredient to the handling portion of the V8V package.
If you’re not willing to run such extreme warm temps, dry weather, fast wearing tires all the time on the street, and aren’t a track junkie (using a 4k lbs sedan?), then I don’t see the value in this package.
While I am sure the Cup2R is a decent tire, it's hardly the key ingredient. There are a LOT of better track tires out there that would work as well or better: Supercar 3R, Sport Maxx Race, P Zero Corsa or Trofeo, Hoosier A7/R7...etc.
The point is the suspension and calibration are now up to the task of handling a really sticky tire. If you aren't tracking, then this isn't the option for you. Personally, I love the idea of the lunatics at Cadillac making my 4k lb sedan an even more capable track car.
I just ran across service bulletin 24-NA-267, which applies to RPO Q2Y (Cup 2 R) tires:
The purpose of this bulletin is to inform dealership personnel that the Michelin Pilot Sport
Cup 2 R tires that are originally equipped on the Cadillac CT5-V Blackwing require
unique maintenance that must be followed.
Important: See Owner Manual for additional information.
Warning: Failure to follow these requirements may lead to tire failure and loss of
vehicle control and may increase risk of injury, death, or property damage.
Replace only as a set. Replace all four tires if any of the tires exhibits damage or if the
wear indicators on any tire can be seen in three or more places on the tire. All tires must
be replaced at the same time and in complete sets regardless of tread life remaining on
the tires. These tires must not be replaced individually or in pairs. The rear tires will likely
wear faster than the front tires.
TSB is not going to be very useful. First, how many enthusiast who run R comp tires would go to the dealership to get new tires? Second, what are the odds a dealership would have a set of R comps in stock to sell? I think the answer is zero.
All this talk about the Cup 2R's? Clearly the 4S TPC Spec is the better tire for daily street driving. The Cup 2R's are desired for track days. But why use Cup 2R's for track days rather than Michelin S8M's or S9M's?
The car is tuned to a certain balance of front to rear grip as well as spring rates that affect this balance under load. This shows up as degrees of under/oversteer at the limit.
The tires themselves are big springs so a change in sidewall stiffness can significantly affect balance (that’s why you can adjust balance by simply changing the air pressure in the tire). This change in sidewall stiffness is also why you see different spec slicks of the same size (e.g. the N spec for the rear engined 911 or the 325 DH slicks that were meant for the front of a Viper)
I’ve met and talked to several of the GM engineers that do this work and it’s all centered around a specific tire. In fact, it’s highly unusual for them to offer two tire options on the PP, they never allowed this on the Corvette Z07 package.
So yes you will get more grip with a slick, but also will affect the handling balance. Most folks are not going to be consistently at the limit enough to notice, they’ll just drive around like Superman with tons of grip below the limit.
