Speed Racer 007
- Joined
- Dec 5, 2021
- Messages
- 787
- Location
- Long Island, NY
- V-Series Cadillac(s)?
- 2023 CT5-V Blackwing- Rift/Manual
The entire thing sucks, hope you receive resolution swiftly!
The placard on my failed engine says it was built by Morgan Beachboard.
Morgan built mine as well, she's very nice and competent I think we are likely to find this is a component issue not assembly issue.Morgan built mine too. Per the registry, he only built 7. What? Me worry?
It's not him or any other builder. We had this discussion before.
I did the same thing lol!!Opps. Morgan's a young lady. My apologizes.
Hey Man I joined these forums to post with you. Just had my 23 CT5 BW with 10k miles go in the shop with a tick. Turns out I need a new motor due to shavings as well. Service has been fast and great. I don’t have loaner issues but haven’t heard back on engine ETA. Which doesn’t matter much because I don’t want the car back anyway. My state lemon laws in 30 days. I’ve heard GM will try to get you a new car before they write you a check. But it’s absolutely insane we are dealing with this on what’s supposed to be a “ hand built “ motor.3 week later update— it took Orr Cadillac in Shreveport 5 days to get the car in a bay and pull the oil filter and find metal particulates in it. Told me I need a new engine and the engine is on back order with no idea when one will be made available. Told me they have no loaners available and the car has to be at their shop ten days for them to provide a rental. Cadillac customer care called right afterwards and told me my new engine was pushed to the very front of the line, even before the new cars being built. Fast forward to today and still no engine build or delivery date. Left a message for Cadillac customer care last Wednesday that has gone unreturned.
Perhaps we should change the oil at 200 miles. If this car has a break in oil, then that might not be recommended.Hey Man I joined these forums to post with you. Just had my 23 CT5 BW with 10k miles go in the shop with a tick. Turns out I need a new motor due to shavings as well. Service has been fast and great. I don’t have loaner issues but haven’t heard back on engine ETA. Which doesn’t matter much because I don’t want the car back anyway. My state lemon laws in 30 days. I’ve heard GM will try to get you a new car before they write you a check. But it’s absolutely insane we are dealing with this on what’s supposed to be a “ hand built “ motor.
The original poster has the exact same symptoms as my car but I caught it in the extremely early baby ticking phase. I have not heard a clear explanation for our specific failure yet. However most seasoned techs will tell you to change the oil in a fresh car immediately just because of machining particles etc. I will be campaigning for a new car and will have the shop change the oil between the truck and me taking it off the lot just to be safePerhaps we should change the oil at 200 miles. If this car has a break in oil, then that might not be recommended.
Check with a GM engineer if you can reach one and ask if there is a break in oil. I know that cars in the past had a break in oil, but I am not sure if our current cars do. Every manufacturer is different.The original poster has the exact same symptoms as my car but I caught it in the extremely early baby ticking phase. I have not heard a clear explanation for our specific failure yet. However most seasoned techs will tell you to change the oil in a fresh car immediately just because of machining particles etc. I will be campaigning for a new car and will have the shop change the oil between the truck and me taking it off the lot just to be safe
I just posted about this in a similar thread - initiate a buyback directly with GM. Bypass the dealer. They don’t care in this instance and they will not advocate for you, at all. Lemon Laws are for lawyers - you don’t need one.I do question if jurisdiction falls under Texas or Louisiana, given the car was purchased in Texas but is registered in Louisiana and is being repaired in Louisiana. I have the Louisiana statute open and there is strong language of qualification at 45 days. Texas appears to have similar language at 30 days.
It's the failure causing the shavings, not the shavings causing the failure. If you see visible shavings or good-sized chunks of metal on the drain plug, you probably have an issue.Perhaps we should change the oil at 200 miles. If this car has a break in oil, then that might not be recommended.
How do we know that it's the failure causing the shavings and not just incompetence in regards to cleaning the engine during the manufacturing process? I agree it is more likely that the failure is causing the shavings.It's the failure causing the shavings, not the shavings causing the failure. If you see visible shavings or good-sized chunks of metal on the drain plug, you probably have an issue.
My stepson's name (that he goes by) is Morgan, and when he was in high school he dated a girl named Morgan.Opps. Morgan's a young lady. My apologizes.
Considering how engines are manufactured (sand casting and then machined) it amazes me that there isn't more crap floating through the engine.How do we know that it's the failure causing the shavings and not just incompetence in regards to cleaning the engine during the manufacturing process? I agree it is more likely that the failure is causing the shavings.
Yea, not common at all, 26,000+ miles now 5th set of tires, 3rd set of pads, and about to do a 4th set of pads. Hundreds and hundreds of track miles and still runs great.Sorry my man! GM will do you right! Your honestly like very. very lucky because unmodified LT4's other than the coveted "Car and Driver" engines don't fail...exceedingly small numbers.
September - October 2023 are going to be 2024 MY cars and to my knowledge failures have been 2022 MY with one or two 2023 models.I'd be interested to know if the build dates of the engines that failed coincide with any days GM was having a strike. Sabotage happens a lot during strikes especially if they drag on.
Now that is complete bulls***. Very sorry to hear this.UPDATE: Tomorrow will be 50 days my CT5-V BW has been at the dealer with a failed engine. I went through the BBB lemon claim system and yesterday GM denied my request for buyback or any sort of extra compensation for diminished value. Their response is this does not qualify under the Texas lemon law (hint, it does) and they will continue to proceed through honoring the warranty. They still are able to provide me with any sort of engine build or ship date, and continue to say the engine is on backorder without any further detail. GM apparently has stopped caring about their customers and their reputation.
I'm not licensed in TX nor do I practice Lemon Law but my understanding is that attorney fees are included in any buyback litigation. Can you get a free consult with a LL attorney?UPDATE: Tomorrow will be 50 days my CT5-V BW has been at the dealer with a failed engine. I went through the BBB lemon claim system and yesterday GM denied my request for buyback or any sort of extra compensation for diminished value. Their response is this does not qualify under the Texas lemon law (hint, it does) and they will continue to proceed through honoring the warranty. They still are able to provide me with any sort of engine build or ship date, and continue to say the engine is on backorder without any further detail. GM apparently has stopped caring about their customers and their reputation.
