Porous Oil Pan!
conipc
Texas
2024 CT5-V Blackwing
Minor leak under the engine is NOT main seal or pan gasket. Diagnosed as an overly-porous pan: Tech cleaned everything, pressure testing found NO leaks, but he could see the pan essentially sweating oil! So, is the pan on a 4BW plastic, steel or alloy? In any case it's a major job to replace.
Woah.... I have seen an aluminum pan sweat once before, the guy said it was related to the differing metals cooling at different rates after track use. Probably different than what is being described here
I think the LF4 uses a cast aluminum oil pan. I don't think porosity issues are anything new with modern aluminum casting processes, at least with GM. My '07 V1 had an issue with a porous rear main cover which was a known issue for the LS2 at the time.
Here is an example of one on eBay.
I haven't heard of a porous modern aluminum oil pan, but they can develop small cracks that are hard to see with the eye. If it keeps leaking press them to swap it out under warranty. It could be a manufacturing defect or result of improper installation.
It's being changed out now under warranty. That is one complex casting! Not surprising there might be a bad spot in all that area and small corners..
Yeah, I was surprised. I've cracked a pan once on an E36 M3 and fixed it with JB weld.
Glad they're taking care of you! Seems like a rare fluke.
Apparently there has been a tech bulletin on this problem. Note that a LOT has to be removed to get it changed, way past the bottom of the engine: Cradles, suspension, damper pulley, etc. Manual lists the job at 19.5 hours!
They really did copy off the Germans.
Here's a parts list. plus the pan itself!!
In what world do you need to remove the intake manifold to change an oil pan?? Are they removing the entire engine?
Apparently they have to move it considerably. All the cradles, mounts, etc have to be moved.
I swear today's engineers do this intentionally. Try swapping a water pump on anything from 2000 on, maybe earlier. How about wanting to reach a spark plug on many cars today. Gotta drop the motor to reach that last one..
