Unplug the X3 connector. I cannot remember which one it is in your picture, but match up the color of the wires with the diagram, and if they all match that's the one. You can either cut the wires 1, 2, and 3 (all of the ANC mics). Or, get a depinning tool (the correct tool is J-38125-215A) and disconnect them from the harness. You might need to Google how this connector releases because it is a little odd. It has a part that slides then you can get to the terminals. Also, I'd make sure all the colors are the same as what is in my diagram, otherwise you'll need to get to the factory service manual for the 4.
