raptor5244
- Joined
- Aug 7, 2022
- Messages
- 908
- Location
- Florida
- V-Series Cadillac(s)?
- 2022 CT4-V Blackwing - 46-381
Some oil pressure specs I ran across in service information. I'm assuming these are likely minimum values fully warmed up as the first listing (for the 2.0L not shown here) said 100 ° C.
3.6L: @ Idle - 69 kPa (10 psi)
3.6L: @ 2, 000 RPM - 138 kPa (20 psi)
3.6L: Piston Cooling Jet Valve OpeningPressure - 2.2-3.0 bar (32.3-44 psi)
Interesting, I have never seen anything close 10psi at idle. Maybe dips to 17psi when over 200 degrees. Since I change the oil yesterday it is up 2-3psi at idle (20 psi at 196 degree oil temp) so I assume the oil thins out over time. I never had a digital gauge with this precision so I never paid much attention to the analog gauges in the past.
