jodakid69
I saw a video of your event in some posting, but I cannot find it now. The video was far away, it was from the car behind you and it is difficult to see the car placement from the angle of the video. However, it seems that you were on the corner curbing and it ends in dirt or grass kind of like the example below.
The process of the front left tire rolling off the curb, onto the dirt, and then back to the pavement; probably upset the suspension just as you were adding throttle. That is all it takes.
Check out these pictures from turn 7 @ VIR, the start of the "Climbing Esses". I was hitting the apex between 90 and 105 but I was almost coasting with the throttle. Note that as you approach the turn, you do not see the problem ahead:
But once you hit the apex, you see the problem. I circled the dirt depression in red. Note the skid lines and the tires. There is a reason those tires are there and not just railing. Based on the skid marks, it seems that multiple cars follow the path towards the tires.
I think that something similar is what happened in your incident. More of a track issue than bad driving. That is why my instructor @ VIR wanted me to take a slow lap in the first two sessions as he pointed out problem areas such as this one.
