Am I the only one burning quarts of oil?
Jpjr
California
2022 CT5V Blackwing
I’ve added three quarts since my last change. Zero leaks. Zero smoke. I don’t get it other than it’s a bespoke motor and stuff happens. Am I just an unlucky unicorn?
My 4BW has not burned a drop. If your adding quarts upon quarts that often, something is seriously wrong with the car.
Over what period of time in miles such as 500, 1500, 5000? Are you checking it the same engine temperature each time in the same parking spot?
Something is definitely wrong here….
Lots of sports cars burn oil, especially forced induction that run on 0w. Hence why the powertrain warranty on most high end cars specifies what defines an excessive amount.
The added oil is over thousands of miles and there is no indication anything is wrong between the engine temp, oil temp, or oil pressure. Just the oil level. Car runs fine.
I’ve added probably a quart of oil in total between oil changes in the 10K miles I’ve driven my 5BW. This includes around 10 track days. I definitely think your use is abnormal and would take it to the dealer.
25K on my 4BW now. Ill see about 1/2 qt used in 5K miles. If your using 3qt between oil changes that's definitely excessive.
I changed mine at 1500 miles and it didn’t look like it burned any during break in. I’m now at almost 3k and thankfully it still doesn’t look like it’s using any.
They put in the wrong oil inside your car
I just went threw the whole summer and the dealership been putin mobile 1 0w40 without the dexos 2 in it
All factory cadillac V are filled with Mobile 1 super car 0w 40 with dextos 2 in it
I bet you your manufacturer oil change lasted the right amount and ever since the 1st oil change been burning like a mother
Wasted my whole summer burning 3L of oil every 2000km thinking something wrong in engine
Make sure your dealership puts the right oil with dexos 2 in it all LT4 will burn others if not
Threads like this (and my current experience dealing with the wife's car and BMW - long story) make me wonder if it's worth the $70 I'll save having the dealer do the first "free" oil service.
Typically the top-notch experienced techs are not the ones doing routine oil changes. And I don't want to discriminate, but it's possible that many of the younger techs may not know how to properly operate the clutch.
Hmm, I wonder if your car will still burn the dexos2 oil as well, since that's also the wrong oil for an lt4.
