Looks good though! At least you have something to stop debris. Did they give any indication as to when they would become available?View attachment 15832View attachment 15831View attachment 15828View attachment 15829View attachment 15833View attachment 15830
They did front and rear. Seattlecubes, you are correct. the way the wheel well liner is positioned there is a pocket that can trap rocks and debris.
They said a few weeks. Check their instagram and facebook. Looks like they have a machine that cuts the material in house, so shouldn't take too long.Looks good though! At least you have something to stop debris. Did they give any indication as to when they would become available?
Bummer. I have the lift pad in your pic and knew about the fit on the front vs. the rear. I was hoping they would come up with special shaped pad for the rear that could be left in place.Bad news about the lift pads. They stated the fronts will clear but the back will not fit because of the diagonal frame that cuts into the pinch weld space, So they aren't going make any for ct4. They did give me their magnetic lift pad and it does seem to clear the front pretty easy. It does hit that diagonal frame on the rear though. View attachment 15837View attachment 15838View attachment 15839View attachment 15840
@hrdboiled do you know if the 4BW tow hook fits the 5BW? According to GMparts, it seems to be the same part number for both. Looks really nice btw!tow hook. They tried on different colors. stupid me forgot to take those pics.View attachment 15834View attachment 15835View attachment 15836
I don't know. I'll take some side by side pics tomorrow.@hrdboiled do you know if the 4BW tow hook fits the 5BW? According to GMparts, it seems to be the same part number for both. Looks really nice btw!
No Problem. Post some pics when you get it installed.@hrdboiled Thanks for the pictures, Really appreciated. I ordered it!
They look identical to 6th gen Camaro blocks. I have multiple puck sets, 2 different width pinchweld puck sets, sometimes they are damaged from prior idiots. Have for Corvette with key and frame saddles. Bolt on pads would definitely make on and off lift easier on these old knees. Pain in the ass lining up pucks on lift arm until contact made and then remembering to remove them after, lost a few that way.These should work according to these folks on site.
I don't have CF rockers so I'm not sure about the clearance issues. I'm going to try and give them a call.
those tow hooks you have are for a 5BW as well? @hrdboiled
Cadillac 20-24 CT5 & CT5-V Lift Pads
Lift Pads for the Cadillac CT5 & CT5-V Blackwing are now available! Made of billet aluminum and designed to be left on the car. These are angled as to not bend the pinch weld as the car is lifted by a floor jack. They come in anodized red or black. These are great for customers that change...zl1addons.com
Is there a preference with the pucks vs this type IDK? These are set and forget so to say, the Pucks?
@Bourbonp is the CT5 towhook guinea pig.Very Cool!!! ^^^^ Once I speak with them I gonna order as well. I really like those tow hooks for the 4BW! Not sure if they will work on the 5BW? I will ask....I agree with you 100%, it's about working smarter not harder now or days for me as well! Thanks for the lead @hrdboiled !
