Dirkbg
Any reasonably light aftermarket wheels would weigh less than OEM even if a bit larger. The OEM standard front wheel on the CT4 BW is 25.2 lbs, but the Apex VS-5RS in the same size is 17.9 lbs. The rear is 18.2 lbs. For a given wheel/tire combo, if the tire profile is reduced when the wheel is increased resulting in the same overall OD, the weight would be the same. The OP seems to want larger overall OD so that would weigh more than a similar setup at the original OD, but like I mentioned a lighter aftermarket wheel would more than make up for that compared to the OEM wheel.
