I appreciate your input but I’m looking for comments from someone who has actually done this.My guess would be that they would be too wide for stock rims. Even if they would fit, the contact patch would effectively be about the same as 315's on the same rim. Another thing to consider (if it is true), I've always been told that to maintain handling characteristics, when uprising the rears, you should upside the fronts by the same amount. As an example, 305 to 315 on the rear, then 275 to 285 on the front and maintain the original factory aspect ratio's. View attachment 24166
Yes, I just did it. I used Toyo R888R 325/30/19. They are amazing and fit, I do have 6mm spacers that I had on previously and I left them in place. Very happy with the outcome. Very good traction with my current mods. Hope this helpsI would like to hear comments from anyone who has put 325/30ZR19 tires on the stock rear CT5V Blackwing wheels. Any clearance issues?
Did you use the spacers to clear the strut or just because you liked the look of the extra poke?Yes, I just did it. I used Toyo R888R 325/30/19. They are amazing and fit, I do have 6mm spacers that I had on previously and I left them in place. Very happy with the outcome. Very good traction with my current mods. Hope this helps
Source for the spacers?I had them on prior to putting the new tires on and just left them in place. I don't think they are necessary but, they do make it look better in my opinion. For the $40 they cost, not a bad thing to have on hand if you are doing the tires.
TadaMark 5x120 5x127 Wheel Spacers 6mm 5x5 Wheel Adapters 78.1mm Bore fit for Chevrolet Corvette 1984-2021 Camaro 1982-2002 Dodge Durango 2011-2021 Je https://www.amazon.com/dp/B0CRKPLGT2/ref=cm_sw_r_cp_apip_jAFaS97FOVvCWSource for the spacers?
Thinking about doing this bc needing to replace the OEM tires but with Michelin Pilot Sport A/S.
This link takes me to a listing for 12mm spacers... Is this actually what you bought or has the listing changed?TadaMark 5x120 5x127 Wheel Spacers 6mm 5x5 Wheel Adapters 78.1mm Bore fit for Chevrolet Corvette 1984-2021 Camaro 1982-2002 Dodge Durango 2011-2021 Je Amazon.com
Looks like the listing changed as when I took into my Purchase History, it also lists the 12mm spacers. I got the 6mm spacers.This link takes me to a listing for 12mm spacers... Is this actually what you bought or has the listing changed?
Amazon.com looks like the new link from the same brand for 6mm. Thanks!Looks like the listing changed as when I took into my Purchase History, it also lists the 12mm spacers. I got the 6mm spacers.
In picture #1 of your post, it looks like you have quite the gap between the spacer and the hub lip. That is NOT safe.Michelin Pilot Sport A/S 4 RF 325/30/19 with 6mm spacers fit!
