HP Increases
I’m newer to this platform and am making an assumption here but you seem to be concerned about failing emissions. I think just a tune will yield big increases and I can’t imagine that would cause you to fail emissions. In Illinois all they do is hook a sensor up to your tailpipe at idle and it’s pass/fail. I can’t imagine an aftermarket tune changing the level of emissions at idle to the point the car would fail. If you removed the cats from the exhaust that would be a different story, but I would think just a tune would be okay.
I'm planning on tuning mine someday. Just want the warranty for now. I have tuned all my cars since the 90's and all passed emissions. We had a guy with open headers trailer his car to an emissions station. Bet the attendants he could pass and he fired it up, they plugged it in and it passed. Drove back on the trailer and went home. Just about anything can pass with plug in inspections with the right tune/file.
I work for an OE and do flash validation. I'll tell you what I know from an OE side and an aftermarket side for my other car....
The OE does tons of testing and tuning, and a majority of it is for EPA. Most cars are tuned down to meet those EPA standards. Yes, there are a few parameters that must be tuned lower to meet the OE's 70% or 75% or whatever it may be for sensor thershold.
Most aftermarket tunes (up until last year when the EPA started really cracking down) will more then likely cause a vehicle to fail emissions testing. I'm not sure how true this anymore as I live in a non-testing state and there's no plans to bring it back.
Now, as far as will a tune void a warranty.... If the car is found to have a tune...100% yes! However, Trifecta used to make an "invisible tune" that stored a tune in non-used memory. You would turn the cruise control to the "ready" position and the tune would switch with the current OE tune. GM got wise to this. So they started reading how many times the PCM was flashed because the PCMs all now keep track of how many times they're flashed and the OE I work for 'bricks' at 99. So everytime you would turn the tune on and off, it counted as a flash and the register number would show that. So GM can void warranties even if you aren't caught with a tune in your car.
Most tunes will take your forced air vehicle to 90% or so of capability, where the OE tune will be about 70-75%. An NA car is much harder to get hp out of without adding some sort of forced air. And NA vehicles are consistently tuned much less then even the 70% thershold because most people won't spend $7k to turbo or supercharge it. Does any of this reduce life expectancy? Let me put it this way. If you're very anal about maintenance, your car should last almost as long as it would have without tuning it. If you don't believe in maintenance, then your car is going to have a short life whether or not it's tuned. My Solstice, and my Caddy will have oil changes every 5k. (new study shows that changing 100% synthetic every 3k is worse then letting it go 12k miles because it doesn't have time to break down and bond...but my thoughts are still out on that!!!) I used to change my oil on my Sol every spring when I pulled it out of storage and every fall before putting it away for the winter....but I only drive the car 2k miles/yr.
My understanding is the fact that a vehicle is tuned does not automatically void the warranty. The manufacturer has to prove that the tune (or modification) caused the part in question to fail to deny the warranty coverage.
Also each platform is very different with respect to built in thresholds. As an example the A45 AMG type S puts out 416hp out of a 2.0L 4 cyl from the factory. This car (AMG) is much higher than the 70% capability from the factory, probably closer to 90%+.
Maintenance and tuning will also be very platform dependent. Some cars you can just tune and get an extra 50whp and never worry about. The Golf GTI on the other hand with a manual will almost certainly require an upgraded clutch if you tune it and that has nothing to do with the maintenance and everything to do with the thresholds of the stock hardware. There are many variables including driving style in addition to the platform that can impact longevity and what is a safe threshold.
Most aftermarket tunes (up until last year when the EPA started really cracking down) will more than likely cause a vehicle to fail emissions testing. I'm not sure how true this anymore as I live in a non-testing state and there's no plans to bring it back.
Do you have first hand experience with this in your line of work? I’m genuinely curious, I’m not in the industry but I have been pretty active in various car forums over the years. While I have personally only tuned one of my vehicles, I have read a lot of information across various platforms and I can’t recall any concerns or problems people have had with emissions and tuning only, though most of my vehicles have been newer and Illinois only requires emissions testing in certain areas and vehicles that are 3 years or older I believe. The only time I have seen people referencing needing to go back to the stock tune is relating to bringing the car into the dealer for any type of warranty work (though that may not work with key cycle counts), but I’ve never read anything about a tune only impacting emissions.
California has been collecting ECU data for years in preparation for checking for tunes. In the last year or two they implemented the program and now scan the ECU specifically looking for tunes during emissions testing. My guess is this was in response to diesel trucks rolling coal. For now, I believe only CA checks for tunes.
CA and EPA have also shut down and fined most of the Diesel tuners - including demanding and receiving customer lists (though I am not aware of them doing anything to customers yet). A few have stepped up to perform the drive cycle tests to sell their (now emission compliant) tunes, or folks are getting tunes from Canada or other countries.
It has always been illegal to tune any car with an emissions label (so every car that was not designed as a race car). There has never been an exception for modifying federally certified cars for racing / off road use, but until the Biden administration the EPA turned a blind eye. In the last few years the EPA and CA have cracked down on both the tuners and end users. I suspect enforcement will only get tougher. Eventually tuners for gasoline-powered cars will likely go underground or become emissions compliant just like Diesel has in the last couple of years
Edit: I just read through the EPA settlement (last link) and it looks like the EPA crack down started during the Trump administration
"33. Respondents violated Section 203(a)(3)(A) of the CAA, 42 U.S.C. §
7522(a)(3)(A), by knowingly removing and/or rendering inoperative emissions-related elements
of the ECM installed on or in motor vehicles or motor vehicle engines that were in compliance
with Title II of the CAA, including the Black Ram 1500 inspected by EPA on July 9, 2019.
Civil Penalty
34. Based on analysis of the factors specified in Section 205(c) of the CAA,
42 U.S.C. § 7524(c), the facts of this case, information that Respondents provided to EPA, and
Respondents’ ability to pay, Complainant has determined that an appropriate civil penalty to
settle this action is $350,000. EPA has reduced the civil penalty based on information provided
by Respondents to support their claims that they are unable to pay a higher civil penalty and
remain in business."
Yes and no. An engine tune won't have anything to do with a failed window regulator. But if there's a drivetrain or powertrain failure, expect that to be not covered. Pay to play.
I'm surprised no one has mentioned the cost of tuning a car running on GM's Global B platform.
1. You have to remove and send the ECM to HP turners to have it unlocked. That's $1500.
2. Next you'll need to purchase an MPV3 dongle from HP Tuners, that's $400.
3. The Blackwings require 8 tuning credits which will run you $500
You'll have $2400 invested before anyone touches the tune. Custom tuning and dyno time will be additional costs.
Then there's cost of performance parts such as headers, ported blowers, pulleys, heat exchangers, and fuel system upgrades to run E.
The horsepower per $ ratio is not good. You better have a wallet full of cash if you're going to add HP to these cars.
This does void the warranty doesn't it? Don
DonD, sounds like you need to stick with a stock vehicle. Keep in mind, even a stock vehicle can fail emissions. 🤷🏼‍♂️
Not necessarily but I will not do anything that would void the warranty. Additionally, I paid for an extended warranty. A dealership might take an unsympathetic position regarding a repair.
Of course I'd like more power just like I'd like more money as long as the cost vs benefit ratio is strongly in my favor.
Plus what hawk02 describes means we're down to one car for a significant period. Neither I nor my wife want the significant limitations one car creates. Don
Your down time will be about a week. My local tuner says he can unlock about 50% of the ECM’s on site. If not it’s overnight to HP and overnight back then a day or so to tune.
And the tune voids the warranty. Don
my advice to you would be for you to add a Gigs ported throttle body and a Tapout oversized air lid with or without the oiled filter. Seat of the pants is a definite difference and you will also see a boost increase of approx 3 psi. That alone is worth the money. If you want to further take advantage of theses two mods add the colder spark plugs and the piggy back JB4 tuner which can be removed before dealer visits. It seems that your main concern is emissions so with that being said I would just stick to the oversized air lid and the Gigs ported throttle body and the colder plugs. enjoy the benefits of the additional boost and it is virtually undetectable. The car will self tune around these small changes.
The only extra cost due to Global B is the $1500 ECM unlock. Everything else is roughly the same on previous GM LT4 platforms. Buying a $100k sedan and complaining about an extra $1500... gotta pay to play, sir!
That was my point. You gotta pay to play. As others have mentioned, you'll void the powertrain warranty. This is another potential out-of-pocket cost if something happens to the engine from tuning and/or modification. And trust me, not all mods/tuning goes well. I know this from experience.
Yes, spending $1500 on a $100K car doesn't seem like much but people need to consider the big picture. The financial ramifications of getting a few more horses could be staggering.
You bought a performance car, and an extended warranty.
You want to up the power without violating the warranty, emissions, or reliability of the car.
Go buy a Honda for a daily driver and make the 4 a toy, or a 5BW. Everything you want to do to your car competes directly with what you don’t want to do to your car.
Im in illinois, and have no idea what you are talking about, all they do is plug the obd2 in, and if no check engine light you pass, my car is catless, and all of mine and my wifes cars have been catless for over a decade, never had a single issue passing emissions catless and with a tune, any of my GM cars, any of her porsches, M cars, or AMGs.
