Dealer says once in V mode, pressing V mode again will always default to Tour mode. Is that true?
MiBlkWing
Ann Arbor
I usually start the car off in My Mode, then when I'm going through a tunnel, press V mode to get some pops and burbles. Then, once I click V mode again, it goes to Tour...not My Mode. I went to the dealer, and they said it will always default back to Tour when pressing V mode button again.
What happens: Start in My Mode -> Press V button-> goes to Vmode -> Press V button again -> but goes to Tour
What I want to happen: Start in My Mode -> Press V button-> goes to Vmode -> Press V button again -> My Mode
Any way to change this default to Tour mode?
No there isn't. At least probably not without coding.
If you want to get out of V mode and back into My Mode with just one button press. Just hit the up or down around on the mode selection near the shifter and it will drop the My Mode.
That's how I do it if I need to leave V mode and go back to My mode.
If you have set the PTM setting in V-Mode, it will go to the programmed PTM settings (rain, dry, sport, track 1, track 2) on the second press if done shortly after pressing the V-mode button the first time. Pushing the mode button by the shifter will cycle through the PTM modes if the PTM modes are active and you need to push the V-mode button again to exit v-mode. This will move it to "tour". Which is good if your police have sensitive ears and they like to ticket for excessive noise.
Mine always defaults to Tour Mode. I'd love to get it to default to My Mode. Now you have me thinking I need to RTFM!
The car will only "stay" in either mymode or tour mode when you turn it off. All other modes will default to tour when the car is turned off. And yes, when you hit the V button a second time, it goes back to tour mode. A small annoyance for sure.
Sport mode also persists after key off.
Seems like the default should be Mymode since that is a customized setting the owners put into the BCM, but hey what do I know? I'm only the customer... :hb
