Aftermarket Wheels for CT5-V Blackwing
By more aggressive, are you referring to the offset?
Those look fabulous. I generally don't like black wheels, even on a black car, but for those I think I could make an exception!
Correct, lower offset by 6mm.
The one car that got me into the black on black theme, was a new C7 Z06 years ago shortly after release. Menacing yet tasteful.
Update: Apex is having a sale right now, through most of April.
Do you think if i tough it out to black friday there will be a better Apex deal?
Hi friends,
I've read a couple threads on aftermarket wheels for the CT5-V Blackwing.
But I'd like to open it up as I'm going through the process of researching aftermarket wheels for 19 or 20" rims.
If you had any success with a set or a rec I'd love to hear them. Thank you in advance.
-Eric
I'm currently rocking with Shift Wheels Piston 20x8.5. I bought them from here with guaranteed fitment, here's the collection.
20” BBS LM r wheels
Anderson Composites, painted the sides to blend in some.
How is the quality, weave pattern compared to OEM, fit, etc?
from their site, pretty impressive: Hoods are hand crafted and weigh approximately 00.0 lbs.
The stock hinge holes are slotted so you for some adjustments there. Makes adjusting it a breeze. Didn’t even had to adjust the striker like on some other cars I’ve had.
These are night and day easier to install than my old carbon creation hood on my old C6Z. The bolt holes and embedded nuts on those were installed crooked by a blind monk.
Picked up my Apex VS5RS wheels last year during their Black Friday sale. Extremely light wheels, and great design. They seem to have a very OEM like design, which I love. Rears are a tad more aggressive than the originals. Fronts are the same width and offset. I swapped over the factory 4S tires and TPS sensors to these. View attachment 25144View attachment 25145View attachment 25146View attachment 25147
@FISH22 these are 19s right?? These look really good on your car. I've seen photos of this wheel in 19" configuration on other cars (albeit different wheel and exterior colors) and they look small/underwhelming. Looks perfect on yours- especially considering your car isn't lowered.
View attachment 27248View attachment 27249
BC Forged LE51
20x10.5 +13 20x12 +50 285/30-20 and 335/25-20 Continental Extreme Contacts2
Pardon my ignorance. When changing wheel and tire sizes is there any effect on the speedo, transmission or other devices that determine maint based on mileage. I have purchased aftermarket wheels for my other vehicles but always kept the ratio as close as possible ( reduced tire sidewall to compensate for larger wheels etc. using an online sizing tool.) Does the BW use the same type of tech and is overall sizing a factor with the mileage etc? PFA previous vsport went from 18 inch to 19 inch wheel but changed tire size to keep almost the same circumference
