So, the Tremec -6060 is one of the best manual tranny's out there, but it does have a couple of quirks.
The gates are very narrow and/or precise. Folks making the transition from other manuals often complain about missing shifts (2nd-3rd is most common). It takes a while for muscle memory to find the gates.
Here is where people will start yelling at me:
About a year after getting my 1LE, I contacted TREMEC and spoke with them about the recommended transmission fluid and service interval. I track my car and wanted to hear their recommendations.
Immediately they said to use their fluid: HP-MTF
High Performance Manual Transmission Fluid (HP-MTF)
He explained that while the GM Dexron fluid works, the GM fluid is a cost saving measure. Not sure if anyone here is familiar with how to change the -6060 transmission fluid, but you drain and then refill, but only up to an 1/8" (or 8 ounces) of the fill port. You do not fill it all the way up. That is the procedure in the service manual and it is due to the expansion properties that ATF has when it gets hot.
Since the HP-MTF is not ATF, it doesn't expand the same way and you can fill the transmission until full. I switched to the HP-MTF when my car had about 8,000 miles on it and have used it ever since. I'm now at more than 100 track hours and 50,000 miles. I change the fluid once a year.
I just used my last batch of HP-MTF and called to get a refill. I was told the facility that distributes the fluid was destroyed by a fire and it would be months to a year before it would be available again. They said in the interim, to use Pennzoil Synchromesh. YMMV
