2025 CT5-V Blackwing LE MONSTRE EDITION & 2025 CT4-V Blackwing PETIT PATAUD EDITION
So no luck in getting info on the Santorini Blue Seat belts? Once I know they are a confirmed fit in a 23' I'm ordering all sets.
Looks like the full set > HERE
Just that a VIN was needed. And so Im feeding this to them. Fitment came up in the talk, I'm not sure about what I heard now that you posted this.
I tried the shortcut and it appears to have failed. Mental note on that.
Did you plug your year and it says they fit?
When I set for a 23' CT5BW, it says "Does Not Fit" but I've seen this before for other GM items which will work but the way it was coded in their DB, if the year/model hasn't be tagged as compatible.
I'm hanging onto hope, I may just order one and see what happens, if it works, I'll grab the rest.
Need one to be born with a VIN so I can move to Phase 2 of the operation. Can't do much with RPO codes from here. Staying tuned.
Folks have mentioned the 150K range for this? Pricey. Not sure if its a daily or your pack it in one of them bubbles and wait 40 years to take her out of there and hope its a score. Its a limited, enough said there. Le Monstre!
are you getting one of these @PrimeTime ?
@PrimeTime Ordered the driver side santorini seat belt kit...ill report back, if it fits, I'll buy the rest.
Staying tuned, hope they fit.
I'm heading to the dealer tomorrow, will ask around a little more about this with a different parts rep this time while I'm there.
Install on the retractors seems pretty straightforward...Good luck @Sully
