Subject: | Information on Crystal White Frost and Dark Emerald Frost Matte Paint Finish |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Cadillac |
ATS-V Coupe |
2016 |
2016 |
ATS-V Sedan |
CTS-V |
CT4-V Blackwing |
2022 |
2022 |
CT5-V Blackwing |
Additional Options (RPO) |
PRIMARY COLOR-EXTERIOR, ABALONE WHITE TRICOAT-LOW GLOSS (144X) (RPO G7V) and Dark Emerald Frost (RPO G7W) |
A limited production run of 2022 CT4 V-Series Blackwing and CT5 V-Series Blackwing vehicles feature a Low Gloss Matte Paint Finish (Dark Emerald Frost – RPO G7W). This finish is similar to the one previously offered on limited 2016 CTS and ATS V-Series (Crystal White Frost Low Gloss Matte Paint Finish – RPO G7V).
Cadillac’s Frost matte finishes are completely unique from other automotive paints and require specific care. Typical gloss paints employ a durable clearcoat finish that reflects light, leaving a bright sheen. A matte finish, by contrast, uses a distinct coating, equally as durable, that diffuses and absorbs light, creating a unique “flat” finish. The result: an appearance that distinguishes your Cadillac as truly remarkable. While the clear topcoat chemistry is the same high quality clear used for the high gloss vehicles, however, special care must be taken to preserve its unique low gloss appearance.
The matte finish requires special care requirements during Pre-Delivery Inspection (PDI) as well as by customers in order to maintain its unique appearance. Dealerships that receive a Cadillac with the matte finish are required to have a sales and service point of contact to ensure the proper paint care requirements are followed.
A Dark Emerald Frost delivery packet will be shipped to the dealership that includes instructions for the PDI process and paint care and a Customer Care Guide. The paint care guidelines must be reviewed with the customer at the time of delivery.
Tip: To maintain appearance of the matte finish, do not rub the paint surface, only wipe lightly. Rubbing the finish will create bright spots and an uneven appearance. Refer to the updated PDI form before washing or servicing vehicles with the matte finish.
Liquid car wash soap and water as well as mild, non-abrasive bug/tar removers are the only cleaning materials that should be used to clean the low-gloss matte paint. For these vehicles, DO NOT:
Normal hand-washing or power-washing does not impact the low-gloss finish of the paint. Remind owners that touch-free car washes are the only safe automatic car washes to use. Commercial car washes with any types of brushes are not recommended. Also, do not use a liquid wax in any car wash system.Immediately remove foreign materials such as tar, tree sap, bugs and salt from the paint surface. To remove the adhesive from shipping labels without forceful rubbing, use a mild solvent-based adhesive remover. Scratches, rub marks and other damage to the painted surface can be touched up similar to other types of paint, but any paint surface imperfection that would normally be repaired by polishing on high-gloss paint must not be attempted on the matte finish.
Tip: If the matte finish is altered, the affected panels will have to be repainted to return it to the intended low-gloss appearance.
Version |
2 |
Modified |
July 28, 2021 – Updated bulletin to include paint finish information on the 2022 CT4 V-Series Blackwing and CT5 V-Series Blackwing vehicles. |
Article ID: 65
Created: October 6, 2021
Last Updated: October 6, 2021
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2016-2022-cadillac-ats-v-cts-v-ct5-v-ct4-v-service-bulletin-15-na-034-information-on-crystal-white-frost-and-dark-emerald-frost-matte-paint-finish-jul-28-2021-65.html
