2010 - 2021 Cadillac ATS-V CTS-V CT5-V CT6-V: #21-NA-108: Information on Engine Overheating, Cooling System Contaminated with Engine Oil - (May 4, 2021)
Subject Information on Engine Overheating, Cooling System Contaminated with Engine Oil
This bulletin replaces PIP5257E. Please discard PIP5257E.
Brand:
Model:
Model Year:
VIN:
Engine:
(3.0L or 3.6L)
Transmission:
from
to
from
to
Buick
Allure
2010
2016
LF1, LFW, LFX, LLT
Enclave
2021
LFY, LLT
LaCrosse
2019
LF1, LFW, LFX, LGX
Cadillac
ATS
2013
2019
LF4, LFX, LGX
CT5
2020
2021
LGY
CT6
2016
2021
LGW, LGX
CTS
2010
2019
LFW, LF3, LFX, LGX
SRX
2010
2016
LFX, LFW
XT5
2017
2021
LGX
XT6
2020
2021
LGX
XTS
2013
2019
LF3, LFX
Chevrolet
Blazer
2019
2021
LGX
Camaro
2010
2021
LFX, LGX
Caprice
2012
2017
LFX
Captiva
2011
2018
LFW, LFX
Colorado
2015
2021
LFX, LGZ
Equinox
2010
2017
LF1, LFW, LFX
Impala
2012
2020
LFX
Traverse
2010
2021
LFY, LLT
GMC
Acadia
2010
2021
LGX, LLT
Canyon
2015
2021
LFX, LGZ
Terrain
2010
2016
LF1, LFW, LFX
Involved Region or Country
North America, Europe, Russia, Middle East, Iraq, Brazil, Chile, Colombia, Ecuador, Paraguay, Uruguay, Venezuela, Japan, GM Korea Company, Cadillac Korea (South Korea), China, Taiwan, Singapore, Australia/New Zealand, Other Africa
Condition
Some customers may comment that the engine is overheating.
Some customers may also comment on one or more of the following conditions:
  • Oil in the coolant overflow reservoir
  • Coolant discharging from the coolant reservoir
Cause
This condition may be caused by a leakage from the main oil gallery to a water jacket through block porosity or thin wall casting.
  • A very thick oil in coolant mix in the radiator and coolant overflow reservoir may be found.
  • The average oil pressure is over 414 kPa (60 psi) and the coolant pressure is 110 kPa (16 psi).
Correction
If a vehicle with this concern has been verified:
  • if equipped, test the oil cooler system for possible leaking into the coolant through the radiator. If the oil cooler tests good, or the vehicle is not equipped with an oil cooler, then reference this bulletin and replace the engine as well as all rubber coolant hoses.
  • If possible, flush the radiator and heater core. Only replace those as needed.
  • if equipped, flush the rear heater core and replace hoses. Only replace those as needed.
Service Procedure
Note: Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Refer to Engine Replace in SI.
Version
1
Modified
Released May 04, 2021
Article ID: 64
Created: May 5, 2021
Last Updated: May 5, 2021
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2010-2021-cadillac-ats-v-cts-v-ct5-v-ct6-v-21-na-108-information-on-engine-overheating-cooling-system-contaminated-with-engine-oil-may-4-2021-64.html
