Subject: | Service Rear Axle Message with DTC C1135 SYM92 |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Cadillac |
CT5-V |
2020 - 2021 |
ALL |
ALL |
LGY |
MHS |
Involved Region or Country |
North America |
Additional Options (RPO) |
RPO G96 Differential, Electronic Limited Slip |
Condition |
Some customers may comment that there is a Service Axle message displayed and possible loss of limited slip differential function |
Cause |
This condition occurs when C1135 symptom byte 92 is set in the K164 Differential Control Module (DCM) |
Engineering has identified a software anomaly that causes the DTC to set prematurely. If code C1135.92 is in History, clear codes using GDS2 and take no further action. Do not replace the K164 Differential Control Module.
A revised calibration is expected to be available in the first quarter of 2021 to address this condition.
A Bulletin will be released to replace this PI when the calibration is available
Note: If the DTC is Current, continue with published Service Information diagnostics.
Version |
2 |
Modified |
11-13-2020 - Created on. 01/26/2021 - Updated expected time calibration will be available to first quarter of 2021. |
Article ID: 51
Created: January 27, 2021
Last Updated: January 27, 2021
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2020-2021-cadillac-ct5-v-pip5763a-service-rear-axle-message-with-dtc-c1135-sym92-jan-26-2021-51.html
