2009 - 2019 Cadillac ATS-V and CTS-V: Service Bulletin: #PIC6162D: Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use - (Jan 19, 2021)
Subject Questions Regarding The Use Of High Performance / High Temperature Brake Fluid During Track Use
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2009 - 2017
All
All
All
All
Cadillac
CTS Sedan V-Sport, XTS V-Sport
2014 - 2019
All
All
All
All
Cadillac
Cadillac CTS-V (VIN A), ATS-V, XTS V-Sport
2016 - 2019
All
All
All
All
Chevrolet
Corvette
2009 - 2021
All
All
All
All
Chevrolet
Camaro
2010 - 2021
All
All
All
All
Chevrolet
SS
2014 - 2017
All
All
All
All
Supersession Statement
This PI has been updated to include additional model years. Please discard all copies of PIC6162C.
Condition / Concern
Some customers may inquire about a section in their owner’s manual that addresses the use of high temperature brake fluid that should be used in their car during track use.
The following is an excerpt from the owner’s manual:
"For racing or competitive driving, it is recommended that the brake fluid be replaced with a high performance brake fluid that has a dry boiling point greater than 534°F (279°C).
After conversion to the high performance brake fluid, follow the brake fluid service recommendations outlined by the fluid manufacturer. Do not use silicone or DOT 5 brake fluids."
Recommendations / Instructions
There are several products on the market that are sold as "racing" brake fluid.
They have various dry boiling points that are well above the specs of standard DOT 3 (401°) or DOT 4 (446°) brake fluid.
While there is no GM high temperature brake fluid that is specifically recommended for track use in these vehicles, customers may use any available brand brake fluid that has a DRY boiling point that meets or exceeds the recommended spec listed in the vehicle’s owner’s manual.
Important: Keep in mind that any type of DOT 5 brake fluid should not be used in these vehicles as it is not compatible with DOT 3 or DOT 4 fluids or the braking systems that they are used in.  Also, it is recommended that this high performance brake fluid should be flushed back out of the system when the vehicle is done on the track and it is being driven on public roads once again.
Refill the vehicle with the recommended type of brake fluid that is listed in the respective Owner’s Manual.
Article ID: 49
Created: January 20, 2021
Last Updated: January 20, 2021
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2009-2019-cadillac-ats-v-and-cts-v-service-bulletin-pic6162d-questions-regarding-the-use-of-high-performance-high-temperature-brake-fluid-during-track-use-jan-19-2021-49.html
