Subject: | Engine Misfire/Tick Noise, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0300 Set |
Models: | 2015-2019 Cadillac Escalade |
2016 - 2019 Cadillac CTS-V | |
2014 Chevrolet Silverado 1500 | |
2014 - 2019 Chevrolet Corvette | |
2015-2018 Chevrolet Silverado | |
2015-2019 Chevrolet Suburban, Tahoe | |
2016-2019 Chevrolet Camaro | |
2019 Chevrolet Silverado LD | |
2014 GMC Sierra 1500 | |
2015-2018 GMC Sierra | |
2015-2019 GMC Yukon, Yukon XL | |
2019 GMC Sierra Limited | |
Equipped with 5.3L Engine (RPOs L83, L8B) or 6.2L Engine (RPOs L86, LT1, LT4) | |
Attention: | This bulletin also applies to any of the above models from North America, Europe, Uzbekistan, Russia, Middle East, Iraq, Israel, Palestine, Argentina, Brazil, Bolivia, Chile, Colombia, Ecuador, Paraguay, Peru, Uruguay, Venezuela, Japan, Cadillac Korea (South Korea), GM Korea Company, China, Taiwan, Thailand, Singapore, Philippines, Egypt, Other Africa, South Africa |
This bulletin has been revised to update the Parts Information section. Please discard Corporate Bulletin Number 15-06-01-002J.
Some customers may comment on a malfunction indicator lamp (MIL) on and/or an engine misfire/tick noise.
Technicians may find DTC P0300 set or in history.
This may be caused by one of the following conditions:
Note: Inspect the camshaft for damage while the lifters are removed from the engine. If damage is found, replace the camshaft per SI.
If SI diagnosis does not isolate the cause of this concern, technicians should inspect for valve operation.
If the valve(s) are not moving, replace the valve lifter oil manifold and affected bank of AFM lifters. Refer to Valve Lifter Oil Manifold Replacement and Valve Lifter Replacement in SI.
If the lifter has spun the bore, the guides should also be replaced.
There are two approved processes for removing the lifter when stuck in the bore.
Note: Be sure NOT to pry on the sealing surface of the block, as shown in the illustration above.
Typically, one of the above approved processes will remove the lifter that is stuck in the bore. If not, the engine will need to be replaced.
With the lifter removed, be sure to inspect the bore for any damage. Typically, the lifter bores will look good with no indication of damage.
Note: Only select the parts the coincide with the repair performed.
Causal Part |
Part Number |
Description |
Qty |
N/A |
12699740 |
MANIFOLD ASM-VLV LFTR OIL (SERV KIT) (L83, L86 or LT1) |
1 |
N/A |
12699793 |
MANIFOLD ASM-VLV LFTR OIL (SERV KIT) (LT4) |
1 |
N/A |
12659260 |
GASKET-CYL HD (6.2L) |
1 |
N/A |
12622325 |
GASKET-CYL HD (5.3L) |
1 |
N/A |
11546959 |
RIGHT SIDE CYLINDER HEAD BOLTS |
10 |
N/A |
11611976 |
LEFT SIDE CYLINDER HEAD BOLT |
1 |
N/A |
11546959 |
LEFT SIDE CYLINDER HEAD BOLTS |
9 |
N/A |
12657093 |
GASKET-EXH MANIF |
1 |
N/A |
12626354 |
GASKET-INT MANIF |
8 |
N/A |
Refer to EPC |
SEAL, EXH SYS |
1 |
N/A |
12619787 |
GASKET-VLV RKR ARM CVR |
1 |
N/A |
12623308 |
GASKET-F/PMP BRKT |
1 |
N/A |
12668553 |
SEAL KIT-F/INJR (O RING) |
2 |
Article ID: 45
Created: December 18, 2020
Last Updated: December 18, 2020
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2016-2019-cadillac-cts-v-service-bulletin-15-06-01-002k-engine-misfire-tick-noise-malfunction-indicator-lamp-mil-illuminated-dtc-p0300-set-dec-17-2020-45.html
