Subject: | MIL illuminated with DTC P1098 and/or P26BB |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Buick |
Encore GX |
2020 |
All |
All |
1.3 L3T |
All |
Cadillac |
CT4 CT4-V |
2020 |
All |
All |
2.0 LSY and 2.7 L3B |
All |
Cadillac |
CT5 |
2020 |
All |
All |
2.0 LSY |
All |
Cadillac |
XT4 |
2020 |
All |
All |
2.0L LSY |
All |
Cadillac |
XT5 |
2020 |
All |
All |
2.0 LSY |
All |
Chevrolet |
Blazer |
2020 |
All |
All |
2.0 LSY |
All |
GMC |
Acadia |
2020 |
All |
All |
2.0 LSY |
All |
Involved Region or Country |
North America |
Condition |
Some customers may comment that the MIL light is illuminated. The technician may find P1098 and/or P26BB set current or history. |
Cause |
This may be caused by a software anomaly, GM is currently looking into the issue. |
Note: For 2019 MY vehicles equipped with the 2.0L LSY refer to 19-NA-022 first, to verify the vehicle has the most current level of software
Note: For 2019 MY and 2020MY Chevrolet Silverado or GMC Sierra vehicles equipped with the 2.7L L3B, refer to 20-NA-100.
Note: For 2021 MY Encore GX & Chevrolet Trailblazer 1.3L L3T, refer to 20-K-010
Note: For 2020 & 2021 MY Encore GX 2021 MY Chevrolet Trailblazer 1.2L LIH, refer to 20-K-009
Check VIN history to determine if one or both of these codes have previously set in the ECM.
If the vehicle has set either code previously, replace the Coolant Flow Control Valve.
If the vehicle has not set either code previously, perform the latest SI diagnostic for the code.
If the SI diagnostic fails to isolate the root cause, do not replace the Coolant Flow Control Valve.
Clear any codes and return the vehicle to the customer.
If either code is set current, and the SI diagnostic isolates the root cause to the Coolant Flow Control Valve, replace the valve and perform the scan tool control function: Engine Coolant Control Valve Mode.
The value should increase and decrease according to the command in the scan tool.
In the event that the customer returns with either DTC set a second time, replace the valve and perform the scan tool control function: Engine Coolant Control Valve Mode.
For vehicles repaired under the Powertrain coverage, use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation |
Description |
Labor Time |
4087438 |
Complete published diagnostics and clear DTC’s |
0.4 Hr. |
*This is a unique Labor Operation for Bulletin use only. |
Version |
8 |
Modified |
09/10/2019 - Created on. 01/17/2020 updated to include reference to 19-NA-022. 03/16/2020- Updated to include additional vehicle model. 04/07/2020- Updated to include additional vehicle platforms equipped with 1.3 L3T engine. 05/20/2020 Updated to include unique labor operation. 06/24/2020 Updated to remove 2019 and 2020 MY Chevrolet Silverado and GMC Sierra vehicles and to add note to refer to 20-NA-100. 10/14/2020 -Corrected engine displacement in red note section to 2.7L. 10/26/2020- Updated to include this note: : For 2021MY Encore GX & Chevrolet Trailblazer 1.3L L3T, refer to 20-K-010. Also remove 21 Trailblazer 1.3 L3T and 2019 XT4 from model list. |
Article ID: 40
Created: October 15, 2020
Last Updated: October 30, 2020
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2020-cadillac-ct4-v-service-bulletin-pip5675g-mil-illuminated-with-dtc-p1098-and-or-p26bb-oct-26-2020-40.html
