2004 - 2019 Cadillac ATS-V - CTS-V - STS-V: Service Bulletin: Interior Cleaning - Instrument Panel (IP), Hard or Plastic Surfaces, Seats, Carpet, Leather, Vinyl, Fabric Cleaner, Stain Remover, Restorer
#06-00-89-029S: Interior Cleaning - Instrument Panel (IP), Hard or Plastic Surfaces, Seats, Carpet, Leather, Vinyl, Fabric Cleaner, Stain Remover, Restorer - Product Availability - (May 6, 2020)
Subject Interior Cleaning – Instrument Panel (IP), Hard or Plastic Surfaces, Seats, Carpet, Leather, Vinyl, Fabric Cleaner, Stain Remover, Restorer — Product Availability
Models 2006 - 2020 GM Passenger Cars and Trucks (including Medium Duty)
(EXCLUDES Cadillac DTS Platinum and Escalade Platinum with RPO R9N – Tehama Leather)
Attention This bulletin also applies to any of the above models that may be Export vehicles.
This bulletin has been revised to update the first Important statement regarding cleaning procedures and products in response to the COVID-19 pandemic. Please discard Corporate Bulletin Number 06-00-89-029R.
Important: GM has updated and enhanced its cleaning procedures in response to the COVID-19 pandemic. Based on U.S. Centers for Disease Control and Prevention (CDC) and Health Canada recommendations, certain disinfectants can be used to help clean surfaces and mitigate against COVID-19. GM has determined that certain of the disinfectants recommended by the CDC or Health Canada have a low impact on interior vehicle surfaces and coatings. For the U.S., these products include Clorox Ultra Clean Disinfecting Wipes (unscented, bleach free) and Clorox Commercial Solutions Clorox Total 360 Disinfectant Cleaner (EPA Reg. No. 67619-38) manufactured by The Clorox Company, ProKure V (EPA Reg. No. 87508-3-89334) manufactured by ProKure Solutions, and Permasafe CLEAN (EPA Reg. No. 82972-1-93718) manufactured by Permasafe Protective Coatings. For Canada, these products include Clorox Commercial Solutions Clorox Total 360 Disinfectant Cleaner (Health Canada DIN 02460769) manufactured by The Clorox Company of Canada Ltd., and Vital Oxide (Health Canada DIN 02422654) manufactured by Vital Solutions LLC. When using these disinfectant products in connection with the enhanced cleaning procedure set forth in this Service Bulletin, it is important and necessary to read the label of the product and to follow the instructions provided, including application method, before using the product. Note that wipes that are scented or contain bleach can cause chemical attack on interior surfaces and should not be used. Additionally, do not use wipes or cleaners that show color transfer to the wipe or a change in appearance of interior surfaces when tested in an inconspicuous location, as those are indicators of chemical attack. While CDC and Health Canada have identified other disinfectant products that help to clean and mitigate against COVID-19, GM has not tested or approved any other products at this time for use on vehicle interior surfaces and coatings. Use of products other than those identified in this bulletin are at Dealer’s own risk.
Note: General Motors recommends cleaning as directed in the Owner’s Manual with mild soap and water, for most all interior surfaces.
To keep the vehicle interior looking the best, it should be cleaned often. It is important to keep the upholstery from becoming heavily soiled. The vehicle’s interior can experience extreme heat, which can cause stains to set quickly. Lighter color interiors may require more frequent cleaning. Care should be taken because newspapers and garments may transfer color to the vehicle’s interior.
Many of today’s interiors are made with new low gloss materials. Permanent damage may result from using cleaners on ANY surfaces (interior trim, instrument panel, carpet, leather, vinyl and fabric) for which they are not intended. Using non-approved products can actually set the stain to the point that nothing can remove it.
Important:
Because it is critical to use only mild, neutral-pH cleaners, General Motors has approved the use of the cleaners and conditioners listed in this bulletin for the cleaning of interiors. These products are in the neutral-pH range and will maintain the best vehicle interior appearance. These products are water-based, biodegradable, and do not contain bleach, solvents or harsh chemicals.
Interior trim pieces on new vehicles, as well as service components, arrive with a protective film. When removing the protective film, adhesive residue may be left on the trim panels/components. The cleaner (for leather, vinyl, plastic and interior paint) is an effective cleaner in removing adhesive residue without causing damage to the component.
Important:
Effective cleaning steps for hard and/or plastic surfaces:
  1. Using a clean towel, apply/spray cleaner — leather, vinyl, plastic, interior paint, directly onto the towel.
  2. Wipe the surface with the towel/cleaner.
  3. If necessary, use a soft bristle brush to work cleaner into the crevasses of the area being cleaned.
  4. Wipe off any excess cleaner from the surface.
  5. Using a clean towel, apply/spray the conditioner (leather, vinyl restorer) directly onto the towel.
  6. Wipe the conditioner onto the previously cleaned area to restore the material to its original luster.
    Important: Today’s interiors are developed and intended to have a low-gloss appearance. It is important to use only products which provide a low-gloss finish in order to maintain the interior’s integrity, customer appeal and satisfaction.
Effective cleaning steps for fabric:
  1. Remove any residue by lightly rubbing the surface with a clean towel.
  2. Choose the appropriate stain remover based on the stain type.
  3. Spray and lightly brush the area with a clean, soft bristle brush.
  4. Gently blot up the stain.
  5. On upholstery/carpet, the use of a fabric protector can help to reduce or eliminate future staining.
Upholstery and Carpet Stains
When cleaning upholstery and carpet stains ONLY, the following cleaning chart will help you determine which cleaner/formula works best on a particular stain. The chart lists many of the common stains. Some complex stains may require the application of both stain removers, one after the other, to remove both food-based oils and synthetic oils.
A soft bristle brush (P/N 88861425) should be used to safely work the cleaner into the leather grain or material. This enables the dirt/stain to be completely removed from the material.
Type of Stain
Gold Formula (P/N 88861403) (in Canada, 88861411)
Red Formula (P/N 88861404) (in Canada, 88861412)
Beer
X
Blood
X
Butter/Margarine
X
X
Catsup
X
Chocolate
X
Coffee
X
Cola
X
Cosmetics
X
Crayon
X
Grass
X
Grease (motor)
X
Gum
X
Ink
X
Iodine
X
Jelly
X
Juices
X
Lipstick
X
Mayonnaise
X
X
Mildew
X
Milk
X
Mustard
X
X
Nail Polish
X
Oil
X
Paint (latex)
X
Red drinks
X
Rust
X
Shoe Polish
X
Sun block
X
Tar
X
Tea
X
Urine
X
Vegetable oil
X
X
Vomit
X
Wine
X
Leather Conditioner/Restorer
A Leather Conditioner/Restorer is also available. The restorer is safe for all vinyl and leather. It is a water-based product and contains essential emollients to restore suppleness, conditions and adds luster without adding gloss. The restorer will also provide protection against re-staining.
Suede/Micro-Fiber Suede
Suede used on GMNA seats includes a fabric soil repellent already applied at the mill. There is no need for adding an aftermarket fabric protector of any type, and GM Materials Engineering does not recommend doing so. The best way to clean the suede is with water, or water plus a mild soap. Fabric cleaners, GM P/Ns 88861404 and 88861403, are available at dealerships and are also recommended for cleaning suede.
Dye Transfer: Dye transfer will happen any time a natural fiber like cotton, silk, wool, or suede comes into contact with leather. The lighter the leather color, the more quickly the dye transfer will appear. Leather should be cleaned on a regular basis so that the dirt and grime do not adversely affect the top coat of the leather. After cleaning the leather, it is important to treat the surface with the restorer.
Extractor Machine and Concentrate
For difficult to clean materials or when cleaning a large area, the best results will be achieved when using an extractor machine and concentrate. General Motors offers the Ruby Extractor (P/N 627–CC-3000AU) through GM Tools and Equipment 1-800-GM-TOOLS, and has released a concentrate for use with the extractor machine.
Whichever extractor machine is used, it should meet the minimum specifications of the Ruby Extractor:
Ruby Extractor Specifications:
Important: The Ruby Extractor also comes with a 6 year Outer Body and 3 year Parts warranty.
Extractor: The Ruby Extractor machine was designed for automotive use and works effectively in the vehicle’s interior. The narrow design of the vacuum head allows detail work in tight areas. The water pressure pump is reduced so the fabric surface is not wet more than is necessary. The dry time is greatly reduced due to less water on the fabric surface, the vacuum head making better contact with the surface and the significant water lift capability of the machine.
Concentrate: The concentrated extraction cleaner is engineered with lower pH levels to help remove alkaline buildup on fabrics. The concentrate should be mixed according to the instructions listed on the container. The available concentrate helps to break the stain down and then the stain is easily removed with less water. The concentrate used in the Ruby Extractor is slightly acidic to remove soap and alkalinity from the fabric surfaces left behind by using improper, soapy solutions. Dirt, grease and grime are more easily removed when the proper solution is used during the extraction process.
Parts Information
Products are available in two sizes; 8 oz / 240 ML and 32 oz / 946 ML bottles.
Cleaner and Stain Remover:
U.S.
Canada
DESCRIPTION
8 oz.
32 oz.
240 ML
946 ML
Cleaner – Leather, Vinyl, Plastic, Interior Paint
88861405
88861401
88861413
88861409
Conditioner – Leather, Vinyl, Restorer
88861406
88861402
88861414
88861410
Cleaner – Stain Remover – Food, Beverage
88861407
88861403
88861415
88861411
Cleaner – Stain Remover – Ink, Grease
88861408
88861404
88861416
88861412
Soft Bristle Brush:
Part Number
Description
88861425
Brush – Vinyl
Concentrate:
Description
U.S.
Canada
Cleaner – Concentrate Cloth/Carpet
88861420 (67.6 oz)
88861421 (2 L)
Available Equipment
Equipment is available by contacting 1-800-GMTOOLS.
Description
Equipment #
Ruby Upholstery Extractor
627-CC-3000AU
Article ID: 22
Created: May 7, 2020
Last Updated: May 7, 2020
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2004-2019-cadillac-ats-v-cts-v-sts-v-service-bulletin-interior-cleaning-instrument-panel-ip-hard-or-plastic-surfaces-seats-carpet-leather-vinyl-fabric-cleaner-stain-remover-restorer-22.html
