2016 - 2017 Cadillac ATS-V and CTS-V: GM TechLink: #16-NA-399: Information on Replacing Half Shaft Fasteners with Revised Parts
#16-NA-399: Information on Replacing Half Shaft Fasteners with Revised Parts - (Feb 28, 2017)
Subject Information on Replacing Half Shaft Fasteners with Revised Parts
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS-V
2016
2017
LF3, LF4, LT1, LT4
CTS-V
2015
2017
Chevrolet
Camaro
2016
2017
Involved Region or Country
North America and N.A. Export Regions
Condition
The technician may need to perform a repair that requires the half shaft bolts to be removed.
Information
This bulletin advises the Service Technician of new retainer assemblies that are required to be installed during any repair that requires the half shaft bolts to be removed or replaced.
Correction
If half-shaft has been separated from the differential:
Service stock half shafts may include POA retainer assemblies that have the shorter bolt (1), these assemblies may require to be exchanged with new retainer assemblies that have the longer bolts (2).
Parts Information
Use the Vehicle Identification Number (VIN), SI, and the GM Electronic Parts Catalog to determine the proper part numbers for the half shaft, if replacement is required:
Description
Part Number
Qty
RETAINER ASM-RR WHL DRV SHF
11601876
3
Article ID: 2
Created: April 28, 2020
Last Updated: April 28, 2020
Author: Rob
Online URL: https://www.cadillacvnet.com/knowledge-base/article/2016-2017-cadillac-ats-v-and-cts-v-gm-techlink-16-na-399-information-on-replacing-half-shaft-fasteners-with-revised-parts-2.html
