Skip to Content
2020 - 2021 Cadillac CT5-V: #PIP5763A: Service Rear Axle Message with DTC C1135 SYM92 - (Jan 26, 2021)
Estimated Reading Time: 1 Minutes
Subject Service Rear Axle Message with DTC C1135 SYM92
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CT5-V
2020 - 2021
ALL
ALL
LGY
MHS
Involved Region or Country
North America
Additional Options (RPO)
RPO G96 Differential, Electronic Limited Slip
Condition
Some customers may comment that there is a Service Axle message displayed and possible loss of limited slip differential function
Cause
This condition occurs when C1135 symptom byte 92 is set in the K164 Differential Control Module (DCM)
Correction
Engineering has identified a software anomaly that causes the DTC to set prematurely. If code C1135.92 is in History, clear codes using GDS2 and take no further action. Do not replace the K164 Differential Control Module.
A revised calibration is expected to be available in the first quarter of 2021 to address this condition.
A Bulletin will be released to replace this PI when the calibration is available
Note: If the DTC is Current, continue with published Service Information diagnostics.
Version
2
Modified
11-13-2020 - Created on.
01/26/2021 - Updated expected time calibration will be available to first quarter of 2021.
