Skip to Content
2020 - 2021 Cadillac CT4-V CT5-V: Service Bulletin: #PIT5817A: SES MIL / Dead Battery / DTC P0700 P2535 U300D - (Mar 8, 2021)
Estimated Reading Time: 1 Minutes
Subject SES MIL / Dead Battery / DTC P0700 P2535 U300D
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Buick
Envision
2021
All
All
All
All
Cadillac
CT4
2020 - 2021
All
All
All
All
Cadillac
CT5
2020 - 2021
All
All
All
All
Cadillac
Escalade Models
2021
All
All
All
All
Chevrolet
Corvette
2020 - 2021
All
All
All
All
Chevrolet
Suburban
2021
All
All
All
All
Chevrolet
Tahoe
2021
All
All
All
All
GMC
Yukon Models
2021
All
All
All
All
Involved Region or Country
North America
Condition
Some customers may comment on the following:
  • SES MIL at start up
  • Dead Battery
When checking the vehicle for DTC’s, the following may be set:
ECM: P0700 and/or P2535
TCM: P2535
BSCM: P2535
IPC: U300D
These concerns may be more likely to occur after using the remote vehicle start.
Cause
The cause of this concern could be the BCM ignition 1 relay (KR73) driver remaining energized after the ignition is turned off.
This will apply power to circuit 5199 for the KR73 ignition main relay, keeping it energized even though the ignition is off, example Document ID: 5430865.
Correction
Follow normal SI diagnostic procedures for DTC P2535 and if it is found that the BCM is keeping power on circuit 5199 after the ignition is turned off, then replace the BCM.
Version
2
Modified
03/01/2021 – Created on
03/08/2021 - Updated the model list
