2019 - 2020 Cadillac CT6-V: Service Bulletin: #19-NA-275: Moan Type Noise Heard During Low Speed Maneuvers - (Sep 29, 2020)
Estimated Reading Time: 1 Minutes#19-NA-275: Moan Type Noise Heard During Low Speed Maneuvers - (Sep 29, 2020)
Subject: | Moan Type Noise Heard During Low Speed Maneuvers |
Brand: |
Model: |
Model Year: |
Breakpoint: |
Engine: |
Transmission: |
from |
to |
from |
to |
Cadillac |
CT6-V |
2019 |
2020 |
4.2L (RPO LTA) |
Involved Region or Country |
North America, Middle East |
Additional Options (RPOs) |
Equipped with BRAKE LINING-PERFORMANCE DRIVING (RPO JE2) |
Condition |
Some customers may comment on a moan type noise being heard during low speeds maneuvers. Note: This noise is most likely to be heard during light brake pedal pressure and/or releasing the brake pedal. |
Cause |
This condition may be caused by the high performance track-capable brake lining generating high brake torque during a brake event. |
Correction |
If the noise concern on the vehicle matches the sound in the audio file shown above, replace the upper control arms. Refer to Upper Control Arm Replacement in SI. |
Parts Information
Causal Part
Description
Part Number
Qty
X
UPPER CONTROL ARM DRIVER SIDE
84836699
1
UPPER CONTROL ARM PASSENGER SIDE
84836698
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
8033030
Use Published Labor Operation Time
Version |
1 |
Modified |
Released September 29, 2020 |
