2016 - 2019 Cadillac CTS-V: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set
Estimated Reading Time: 2 Minutes#20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set - (Sep 25, 2020)
Subject: | Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set |
This bulletin replaces PIP5590A. Please discard all copies of PIP5590.
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Cadillac |
CTS-V |
2016 |
2019 |
All |
All |
6.2L (LT4) |
All |
Escalade |
2015 |
2019 |
All |
All |
6.2L (L86) |
All |
Chevrolet |
Camaro |
2016 |
2019 |
All |
All |
6.2L (LT1, LT4) |
All |
Corvette |
2016 |
2019 |
All |
All |
6.2L (LT1, LT4, LT5) |
All |
Silverado |
2014 |
2018 |
All |
All |
4.3L, 5.3L, 6.2L (L83, L8B, L86, LV1, LV3) |
All |
Silverado LD |
2019 |
2019 |
Suburban |
2015 |
2019 |
All |
All |
5.3L (L83) |
All |
Tahoe |
2015 |
2019 |
All |
All |
5.3L (L83) |
All |
GMC |
Sierra 1500 |
2014 |
2018 |
All |
All |
4.3L, 5.3L, 6.2L (L83, L86, L8B, LV1, LV3) |
All |
Sierra Limited |
2019 |
2019 |
Yukon Models |
2015 |
2019 |
All |
All |
5.3L, 6.2L (L83, L86) |
All |
Involved Region or Country |
North America, Uzbekistan, Russia, Middle East, Israel, Palestine, Colombia, Ecuador, Paraguay, Japan, Singapore, Philippines, Other Africa |
Condition |
Some customers may comment that the MIL is illuminated. Some technicians may find one or more of the following DTCs set in the Engine Control Module (ECM).
Cause |
This condition may be caused by a possible high pressure fuel pump. |
Correction |
If SI does not isolate the cause of the rich condition, the following information may be helpful:
With this concern, we do not see a lot of fuel in the crankcase, so changing the oil may not isolate the concern. When the high pressure fuel pump leaks, the PCV will pull the fuel mist straight into the intake, causing the concern. |
Version |
1 |
Modified |
Released September 25, 2020 |
