2016 - 2018 Cadillac CTS-V: Service Bulletin: #20-NA-207: Information on Malfunction Indicator Lamp (MIL) Illuminated - DTC P0333 Set - (Oct 6, 2020)
Estimated Reading Time: 1 Minutes#20-NA-207: Information on Malfunction Indicator Lamp (MIL) Illuminated - DTC P0333 Set - (Oct 6, 2020)
Subject: | Information on Malfunction Indicator Lamp (MIL) Illuminated - DTC P0333 Set |
This bulletin replaces PIP5576. Please discard PIP5576.
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Cadillac |
CTS-V |
2016 |
2018 |
All |
All |
6.2L (LT4) |
All |
Escalade |
2015 |
2018 |
All |
All |
6.2L (L86) |
All |
Chevrolet |
Camaro |
2016 |
2018 |
All |
All |
6.2L (LT1, LT4) |
All |
Corvette |
2016 |
2018 |
All |
All |
6.2L (LT1, LT4, LT5) |
All |
Silverado |
2014 |
2018 |
All |
All |
4.3L, 5.3L, 6.2L (L83, L8B, L86, LV1, LV3) |
All |
Suburban |
2015 |
2019 |
All |
All |
5.3L (L83) |
All |
Tahoe |
2015 |
2019 |
All |
All |
5.3L (L83) |
All |
GMC |
Sierra |
2014 |
2018 |
All |
All |
4.3L, 5.3L, 6.2L (L83, L86, LV1, LV3) |
All |
Yukon Models |
2015 |
2018 |
All |
All |
5.3L, 6.2L (L83, L86) |
All |
Involved Region or Country |
North America, Europe, Russia, Middle East, Israel, Chile, Colombia, Ecuador, Venezuela, Japan, GM Korea Company, China, Taiwan, Thailand, Singapore, Philippines, Other Africa |
Condition |
Some customers may comment that the MIL is illuminated when shifting the transmission from Park. Some technicians may find DTC P0333 (Knock Sensor Circuit High Voltage Bank 2) set in the Engine Control Module (ECM). |
Cause |
DTC P0333 can set due to voltage from the transmission park/neutral signal 1 circuit bleeding into the knock sensor system circuits. |
Correction |
To correct this condition, follow service information for diagnostic code P0333. If service information does not isolate the concern, then inspect the K20 ECM X2 electrical connector for debris, connector and/or terminal concerns. |
Version |
1 |
Modified |
Released October 06, 2020 |
