2014 - 2019 Cadillac ATS-V - CTS V-Sport: Service Bulletin: #19-NA-256: Diagnostic Tips for Knocking, Rattle, Squeak and/or Squeal Type Noise from Engine
Estimated Reading Time: 3 Minutes#19-NA-256: Diagnostic Tips for Knocking, Rattle, Squeak and/or Squeal Type Noise from Engine - Engine Replacement Recommendations for HFV6 Gen 1 and Gen 2 - (Jan 14, 2021)
Subject: | Diagnostic Tips for Knocking, Rattle, Squeak and/or Squeal Type Noise from Engine – Engine Replacement Recommendations for HFV6 Gen 1 and Gen 2 |
This bulletin replaces PIP5216G. Please discard PIP5216G.
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: |
from |
to |
from |
to |
Buick |
Enclave |
2008 |
2021 |
3.6L (LLT, LFY) |
LaCrosse |
2010 |
2019 |
3.0L (LF1, LFW) 3.6L (LLT, LFX, LGX) |
Regal |
2018 |
2020 |
3.6L (LGX) |
Cadillac |
ATS |
2013 |
2019 |
3.6L (LFX, LGX) |
ATS-V |
2016 |
3.6L (LF4) |
CT6 |
2016 |
2020 |
3.0L (LGW) 3.6L (LGX) |
CTS |
2007 |
2019 |
3.0L (LF1, LFW) 3.6L (LY7, LLT, LFX, LGX) |
CTS V-Sport |
2014 |
3.6L (LF3) |
SRX |
2007 |
2016 |
2.8L (LAU) 3.0L (LF1, LFW) 3.6L (LFX) |
STS |
2007 |
2011 |
3.6L (LY7, LLT) |
XT5 |
2017 |
2021 |
3.6L (LGX) |
XTS |
2013 |
2019 |
3.6L (LF3, LFX) |
Chevrolet |
Camaro |
2010 |
2021 |
Caprice PPV |
2012 |
2013 |
3.6L (LFX) |
Captiva Sport |
2012 |
2015 |
3.6L (LFX) |
Colorado |
2015 |
2021 |
3.6L (LFX, LGZ) |
Equinox |
2008 |
2017 |
3.0L (LFW, LF1) 3.6L (LFX) |
Impala VIN W |
2012 |
2016 |
3.6L (LFX) |
Impala VIN 1 (including Bi-fuel) |
2014 |
2016 |
3.6L (LFR, LFX) |
Impala |
2017 |
2020 |
3.6L (LFX) |
Malibu |
2008 |
2012 |
3.6L (LY7) |
Traverse |
2009 |
2021 |
3.6L (LLT, LFY) |
GMC |
Acadia |
2007 |
2021 |
3.6L (LY7, LLT, LGX) |
Canyon |
2015 |
3.6L (LFX, LGZ) |
Terrain |
2010 |
2017 |
Pontiac |
G6 |
2008 |
2010 |
3.6L (LY7) |
G8 |
2008 |
2009 |
3.0L (LF1, LFW) 3.6L (LY7, LLT) |
Torrent |
2008 |
3.0L (LFW) 3.6L (LLT) |
Saturn |
AURA |
2007 |
2009 |
3.6L (LY7) |
VUE |
2008 |
2010 |
3.6L (LY7) |
OUTLOOK |
2007 |
3.6L (LY7, LLT) |
Involved Region or Country |
North America |
Condition |
Some customers may comment on one or more of the following conditions:
Cause |
This condition may be caused by a crankshaft main or rod bearing failure. |
Correction |
Service Procedure
- Inspect the oil control solenoids for metal debris. This shows the oil filter is in by-pass and unfiltered oil with bearing debris was pumped into the oil lubrication galleys, throughout the engine.
- Inspect for damage to the cam caps journals and camshaft journals on the heads (obvious signs of metal through the cap).
- Inspect the timing chain idler sprockets for stiffness when turning (Should turn smooth and free).
Any of the above 3 instances would be cause to replace the engine instead of repair.
While engine replacement at this point will be necessary, additional inspections should also be made for conditions:
- Sludging caused by lack of maintenance. Refer to the latest version of Service Bulletin 16-NA-222.
- Global oil starvation caused by running the engine very low on oil.
- Intentional abuse to the engine.
Important: If this is the case, then a call to the Technical Assistance Center (TAC) is NOT required prior to engine replacement.
If these conditions exist, warranty could be declined or feedback made on Warranty Parts Center (WPC) inspection. Maintenance documentation should be obtained in these instances for warranty validation.
Clearly document your findings on your repair order, fill out the cost worksheet, and call Product Quality Center (PQC) only if required for your dealer.
A repair and then replacement will usually be cause for additional inspection and scrutiny that could result in more questioning about the repair methods.
HFV6 engines are scheduled to be returned to the WPC for inspection to verify the concern, as well as the information provided in the repair order to support the engine replacement.
Version |
2 |
Modified |
Released November 13, 2019 January 14, 2021 – Added the 2021 Model Year to applicable Models. |
Additional SI Keywords: PIP5216, PIP5216A, PIP5216B, PIP5216C, PIP5216D, PIP5216E, PIP5216F, PIP5216G, PIP5216H, PIP5216I, PIP5216J, PIP5216K, PIP5216L, PIP5216M
