Skip to Content
2014 - 2019 Cadillac ATS-V CT4-V CTS-V: Service Bulletin: #PIP5784: 8L45 8L90 Automatic Transmissions With No Movement After Valve Body Replacement - (Mar 1, 2021)
Estimated Reading Time: 2 Minutes
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS Models
2016
2019
All
All
All
M5N M5T M5U
Cadillac
CT4 Models
2020
2021
All
All
All
M5N
Cadillac
CT6
2016
2018
All
All
All
M5N M5X
Cadillac
CTS Models
2016
2019
All
All
All
M5N M5U
Cadillac
Escalade Models
2015
2017
All
All
All
M5U
Chevrolet
Camaro
2016
2021
All
All
All
M5T M5U
Chevrolet
Colorado
2017
2021
All
All
All
M5T
Chevrolet
Corvette
2015
2019
All
All
All
M5U
Chevrolet
Express
2017
2021
All
All
All
M5U MQD
Chevrolet
Silverado
2015
2018
All
All
All
M5U M5X
Chevrolet
Silverado 1500 LD
2019
All
All
All
MQE
Chevrolet
Silverado 1500 Mew Model
2019
All
All
All
MQE
Chevrolet
Silverado 1500
2020
2021
All
All
All
MQE
GMC
Canyon
2017
2021
All
All
All
M5T
GMC
Savana
2017
2021
All
All
All
M5U MQD
GMC
Sierra
2015
2018
All
All
All
M5U M5X
GMC
Sierra 1500 Limited
2019
All
All
All
MQE
GMC
Sierra 1500 New Model
2019
All
All
All
MQE
GMC
Sierra 1500
2020
2021
All
All
All
MQE
GMC
Yukon Denali
2015
2017
All
All
All
M5U
Involved Region or Country
North America
Condition
Technician’s may find a no movement condition after replacement of the valve body on the 8L45 or 8L90 automatic transmission.
Cause
This may be due to the incorrect 1-2-7-8-R clutch fluid passage seal being installed or it is missing.
Correction
Technician should remove the transmission valve body and inspect for the 1-2-7-8-R clutch fluid passage seal to be installed correctly.
If the 1-2-7-8-R clutch fluid passage seal was installed during the valve body then the technician will need to measure the length of the seal to make sure the correct seal was installed.
The 8L45 seal part number is 24262438 and the seal has no ID notches. This seal is 33.5 MM tall.
The 8L90 seal part number is 24259218 and the seal has 5 ID notches. This seal is 23.1 MM tall.
Version
1
Modified
03/01/2021 — Created
