Hey guys, I was wondering if I could get some help from someone on a small problem I have run into with the car.
1st thing- Under a load, say 5th or 6th gear at lower rpms, if I get into the throttle a little bit to pick up speed, the engine will stutter or miss a little bit until I get up into higher RPM's.
It also does it if I drop down a gear to make a pass, at 3/4 throttle or so. Almost like when you get bad gas in the car, likewise symptoms. I have ruled out bad gas though, BC I have been
through several tanks at different stations and the problem has continued.
Im wondering if its a bad spark plug? dirty/bad injector? MAF sensor problem?
Also, occasionally the car will idle around 2000 RPM's while coming to a stop. Then, after Im stopped for a couple seconds, it will drop down to around 1000 where its supposed to be. Holding in the clutch
helps a little, and will only allow it to go up to around 1500 RPM's before it drops down. The weird thing is, it only does this every now and again. But when it does, it will do it consistently for a while.
Also, on startup, it will idle perfectly every time. It only does the high rises after its been put into gear and driven above 2000 RPM's.
MOD's on the car
Texas Speed Torquer V.2 Cam
Ported intake and throttle body
cold air intake
upgraded springs
valves
pushrods
timing chain
High flow oil pump
High flow water pump
1 7/8 long tube headers
X-pipe
Dynomax Bullet mufflers
06-07 rear end
adjustable groundforce lowering kit
skip-shift eliminator
Ls7 clutch
lightened flywheel
short throw shifter
creative steel transmission mount
and aftermarket shifter bushings
Any ideas?
Thanks a ton for the help guys!
MOD's on the car
cold air intake
upgraded springs
valves
pushrods
timing chain
High flow oil pump
X-pipe
06-07 rear end
Ls7 clutch
lightened flywheel
short throw shifter
Any ideas?
