BrakeFade
Experienced Blackwinger
What is everyone seeing for engine oil pressure at idle (at temp) and driving around 4500 and up? I’m seeing 39psi at idle and 46/49 at 4500 on a 5BW 6MT.
Update
I just read the LT4 uses a variable displacement oil pump. So oil pressures won’t get that high. 25-50psi range on average between conditions such as cold start, idling at temp, and spirited driving appears to be normal.
Update
