I put my winters on over the weekend, having mostly copied
Nofar's setup (same Forged One Competition FF05 wheels in 18x9.5 +20mm front, 18x9.5 +33mm rear, but with 255/35R-18 Michelin Pilot Alpin tires on all four corners).
I have 100 miles on this setup already with no issues. The included TPMS and lugs worked perfectly, and everything fit fine with no rubbing. However, I do agree with Tire Rack that this is an "aggressive" fitment. The offsets of these wheels bring them about even with the fender, which is to my taste, but might not be for everyone. There's also very little clearance for going with a larger tire before you start rubbing the suspension, so definitely be careful if you want to try a different tire size.
I've attached a few pictures that show the tight suspension clearance, as well as the offset difference when I had one side of the car done. Also, the jack points on this car are a real pain compared to what I'm used to.
